Hello, I am brand new to this forum and helping a friend out with his 85 350 4WD pick up. It only has 68,000 miles on it and has been sitting for 10 years or so. The engine backfires through the carb when we try to start it and sometimes throws a good size fireball up too!
It has the 4bbl Ford/Holley double bowl carb which I rebuilt. Also I can't get the choke to operate consistently so I have to hold the choke closed to start it again even if it is still warm. I checked the timing with the vacuum hose disconnected and the mark jumps around about 20 degrees or so. When I took for a test ride it would stall if I gave it gas too fast and doesn't have much power.
After reading a ton of threads with guys having the same issue I'm thinking this is a common problem maybe??? Has anybody discovered the fix for this problem??
Thanks in advance for ANY help and suggestions!
