1 - 3 of 3 Posts
Car has 528 with A429 heads,11.5.1 compression, motorsport roller cam A514, victor intake with holley 950, scat internal balance crank , eagle rods, crower stainless rockers, jomar stud girdle.Only 25 passes on freshen up.
Transmission is a glide with jw bellhousing and protree transbrake.
Rearend is a ford 9inch 3.89 gears
front suspension full Pa racing setup with 2.5 drop and pinto rack.
rear suspension has koni coilovers, and anti roll bar, car still uses factory control arm mounting points with aftermarket arms and aerospace disc brakes
Rims and tires= centerline rims with 28x10.5 on back with plenty of rim to go wider and 25x4 on front.
Car has ran 10.13 and is consistent in the 10.18's at 133mph 60fts are around 1.43 with a best of 1.41 I think its probably a 1050 Dominator away from getting into the 9's
The car has a full 10point cage and the tin work in the car is pretty nice
I am asking 11,000 and if your interested email me for pictures or call me at 1-605-376-4576 Thanks,GP
1 - 3 of 3 Posts
