88 mini tubbed notchback Mustang Drag Radial
http://www.flickr.com/photos/[email protected]/sets/72157601553407226/
Rear:
Wolfe racecraft mini tub kit
8.8 rear w/ welded tubes, 9in ends and narrowed 2" per side, 31spline Moser axles, Richmond Full Spool, Richmond 4.10 gears
T/A girdle cover
Hal coilover shocks w/ Hypercoil springs
UPR upper/lower control arm
Custom Gary Rohe anti roll bar
Front:
AJE K-member
QA-1 a-arms
D&D coilovers w/ stock struts
Flaming River manual rack and shaft
UPR c/c plates
UPR bump steer kit
Manual brake conversion
Adjustable proportioning valve
Hurst line lock
5 lug rotors and stock calipers
Interior:
12pt mild steel cage w/swing out door bars
Corbeau Forza seats
Custom sheet metal rear seat delete
Guages- Autometer phantom tach, speedo, oil press, water temp, volt, vacuum, fuel level, trans temp and Dynojet wideband O2 mounted in a custom made guage cluster
ARC switch panel
MSD Digital 6 box
Mallory Promaster coil
Optima red top battery
Tinted glass by the master Sir Dedpedal
Exterior:
All stock except for 325/50 Mickey radials mounted onWeld ProStar 15x10's in the rear and Jegs 15x4 Pro star look alikes w/M/T 8ply Sportsmans on the front
Custom fold down license plate w/ hidden on/off switch
HO Fibertrends 4in cowl hood
Autometer Fuel pressure gauge mounted under the hood visable from driver seat.
12 Volt charge panel with volt gauge inside fuel door.
Bullet Race mufflers with turn downs.
Drivetrain:
429 big block w/ motor plate
All stock except for a Lunati 61603 Voodoo cam, Crane roller rockers and 11.5-1 forged pistons and Weiand intake w/ a QFT 830 Super Street Carb running e85
Hooker Super Comp headers
MSD Pro Billet dizzy Taylor wires
Meziere electric water pump
C4 w/ manual valve body and 10in billet converter
Tranny cooler
TCI Outlaw shifter
FMS aluminum driveshaft
FMS driveshaft loop
Fuel System:
15 gal Jaz aluminum fuel cell
Holley black fuel pump
Mallory Comp140 fuel filter
Holley black regulator
Quick Fuel 830 super street carb converted to e85
All braided for the feed and aluminum for return
Car is tagged and insured. Can be driven on the street. All lights turn signals work. I have Title in hand and will be given to buyer with a bill of sale.
You can give me your cell phone number and i can send you a video of it running.
Car has went 7.20 with the 3.08 gear in it. Havent ran it yet with the 4.10 gear. Should go in the high sixes easy. It cuts 1.50 sixty foot times. That is 1/8 mile times.
I bought this car from mustangboy on here back in march. He built this car and tell you all about it. Wife suprised me with a divorce and need to sell it.
The last thing it needs is paint and then a good home.
12,500 OBO
Seller Phone Number: 229-854-6938
