1 - 3 of 3 Posts
9 " Housing needs narrowing, has early big ford ends to weld on it, and
2 rear Strange rotors and caliper brackets,
two sets of caliper brackets one for big ford axle housing end and one for late model.
No axles included, obviously since the housing isnt narrowed yet.
No brake caliper, but these are standard from Strange. I kept mine cause they are going on the floaters, they are interchangable.
this stuff is all new with the exeption of the housing and it is sandblasted and painted with POR rust inhibitor.
Also can include axle bearings for a Strange 40 spline gun drilled axle with the early big ford ends. yes the end does matter. They are new also, paid $100 will take $50.00
$350.00 for all of it, plus shipping. OR if you just want the Strange stuff with the bearings, I'll take $250.00 thats rotors, two sets of caliper brackets, housing ends and bearings.
would you sell the brackets and rotors? are the rotors new and what diameter? can i still get calipers for it and do you know how much they are? i dont need the ends or the bearings. i have a housing with 31 spline axels. thanks, stang14
some one spoke up through PM before you but if it falls through I'll get back to you. But to answer your questions YES strange sells the calipers, MOST of their stuff interchanges so typically a caliper will fit different applications. It's the Bracket that is different.
Also, it is all new. I think the diameter of the rotors are 11" I'd have to look to be sure.
1 - 3 of 3 Posts
