Bare 90 Notch shell that just recently had a MS 25.5 installed (ID Plate from the chassis shop on drivers down tube with serial number). Plated for BBF/Glide at a 1 inch offset. Wild Rides Lower Battle boxes installed and tied in. Double AA upper control arm cross member installed and tied in. Double AA caster/camber plates installed. Front frame from the strut towers foward is tubing and tied into the cage. Lower core support is tubing. All belt tabs installed. Window net supports installed. Mini tub installation started on right side - DMC mini tubs included, front sheetmetal and bumper $5500. Title in hand. or
Including Kirky seat, Holcomb light weight aluminum steering column and wheel, Racecraft seat mount, Double AA Moly outlaw K-Member $5750.
This about 45 cents on the dollar.:eek:
Recently put in epoxy primer and stock suspension hung for transport.
Trades considered.
Looking to go in a different direction. Located in Western Pa.
[email protected]
