93 Notchbacl LX 1971 429 Stock bore & stroke. DOVE-C heads. Summit cam, Trickflo hardened pushrods & guide plates, roller rockers, Crane anti pump-ups.Edelbrock torquer & 750 mechanical. Holley blue pump. 6-Al stock dist with Accel point elimanator. 100 amp alt conversion. Hookers with 3" dumps. C-6, shift kit, 2500 stall. Hurst promatic installed with Hurst 1/4 stick as spare. Complete tublar front end with 90/10 coil over drag shocks and adj upper plates. 8.8 with 2004 s-trim spool, Mosier axles and 3/73 gears.Heave duty control arms and springs. Subframe connectors, 4 point cage. 99 Cobra hydroboost conversion, yes, it stops as fast as it takes off!! Need fast cash for house re-pipe, have 18,000 gallon water leak!! $5000 OBO located in S/W Fl. 941-204-9226
