Status
Not open for further replies.
i have a 93 roller coupe that is mini tubed,has a 10 point mild steel cage,it has 1 race seat, the bulk head is done just needs sealed up. it has a b&m pro bandit shifter in it for a glide with a eletric piece that shifts the tranny that works off a 7AL3.i have upr k member with 110 springs. i have AQ 1double adj rear shocks. it has a 9in from autoweld that is 6 in shorter than a stock 8.8. it has willwood rear brakes and aerospace front brakes. it has a roll contral, anti roll bar,the 9 inch is back braced and powered coated black has 5/8 rear wheel studs. it has the big input shaft 35 spline and 40 spline axles. it has a flaming river manual ster rack. has a 10 gallon fuel cell and a A 1000 fuel pump and a Aeromotive 13202 reg. it has a Aluminum rad and a eletric fan. has a Optima Battery. the car has wheelie bars, chute mount. has a pull on/off switch. has billet spec rims 15x3.5 and 15x10s in the back. has a new 7AL3 box mount to the cage needs wired up. the car has a 5.5 hood on it. has a new fuel pressure gause and oil pressure. has a skinny kid wing on it.the rear contal arms are doulble adj and has 5/8 bolts holding them on tot the car and rear end. i have the title. the rear end has a pro geasr 4:11, spool i just spent over 5000.00 on the rear end. it does need a front bumper cover the car is 9500.00
Status
