1 - 15 of 15 Posts
1994 Cobra Crystal White Black Interior
$7500.00
I have a load of money and time in this car so I am very firm on the price.
460ci Big Block Ford (just rebuilt)
D0VE heads with fresh new valves and 3 angle valve job. Some port work.
Comp Cams K34-250-4 kit
Crane cam roller tip rockers
Edlebrock RPM intake
Holley 850 carb built by JET
Motorsport valve covers
3 core aluminum radiator
Twin electric fans
CSR electric water pump
D&D 460 engine swap kit
Kit includes
2 1/8” individual tube header with removable 3 1/2 inch collector
7qt competition dual sump oil pan & pickup
D&D’s welded front & mid plate frame mounting brackets with hardware,6061 T6 Aluminum front motor plate , mild steel mid plate
Dual lateral engine limiter kit.
Single chamber mufflers with turndowns
C4 transmission (just rebuilt)
Performance automatic reverse manual valve body with trans brake
PA servo
PA hardened input shaft
All new bands and clutches
9 inch 3800 stall converter
460 ultra bellhousing
SFI flexplate
B&M hammer shifter
B&M Trans coller with fan
UPR adjustable uppers & lower control arms
UPR anti-roll bar
Full length sub-frame connectors
Rear Qa1 adjustable shocks
Rear coil over spring setup
Brembo drilled & slotted rotors
Battle boxes
Stock rear (didn't get to that)
Aje tubular K member with 1.5 inch drop rack
Aje tubular control arms
Aje caster camber plates
Aje front coil over
Strange adjustable struts
Flaming river manual rack/ adjustable steering shaft
Brembo drilled & slotted front rotors
All new brake lines
B&M roll control
Strange manual brake kit
Mallory fuel pump
Wild rides fuel tank sumped in stock tank
-8 AN line
MSD distributor
MSD 6a
MSD coil
Motorsport plug wires
Taylor aluminum battery box in trunk
10 point S&W full cage
Smoothed engine compartment
3 inch cervini cowl hood (not painted or on car)
Stock hood
Rear seat delete
15X10 weld pro stars with 275/60/15 BFG drag radials
15X4 weld pro stars with 165R15
5% window tint
Clear corner lights
Stock cobra seats with 5 point harnesses
Stewart Warner monster tach, oil pressure, water temp, amp,
No heat
There are a few things that need to be done or you need to buy.
I have a new chrome single wire alt. needs to be installed
Prob needs a driver window motor. I tryed a swich and that didnt work.
Needs a new cowl grill. I have one but it is cracked.
Any other ?s email [email protected]
or call 717-538-9018
Nice car! Whats your price? I have a friend looking for a car like that, but he only wants a roller! :roll:
Thanks for the smokin deal Ryan!!! Anybody who wants to deal with Ryan rest assured he is as straight up as they come, car was EXACTLY as described if not better. I would have no problem buying ANYTHING from him sight unseen in the future. Very good people!!!!!!!!
you beat me to it by about 30 mins i went to the bank to get the money and when i came back you had already sent him money. that car was a great deal glad to see it go to a good home.
311reaper aka stdjsw311
Discussion Starter #15
Same goes for Mick. He is a great guy to deal with even though he scared the crap out of me!!!!!! I thought I would have to drive that 1000 miles!!! Anyway again an awsome guy
1 - 15 of 15 Posts
