Hi all, if this isn't the right place for this, please move it. I just made an account because I'm at my wit's end with an issue I've been chasing for a while. I bought this truck a little over a year ago, 95 F250 regular cab long box 2wd with the 7.5L 460. 22X,XXX miles on the odo.
It had sat for a few years but compression test looked ok (between 155 and 140 all around). EGR and emissions were all removed. Started and ran strong, CEL, ABS, and P Brake lights all on. It had a front main seal leak and an exhaust leak where the manifold met the block. Midships tank worked great, rear tank caused it to run poorly. I jumped the test block and read the codes:
31- EGR Position below voltage
67- Neutral safety
82- Supercharge bypass
85- Canister purge
84- EGR vac fail
I brought it home, pulled the engine, had the crank polished, new main bearings, new main seal, oil pan gasket, timing kit, water pump rebuild, plugs, wires, and a clutch. All motorcraft/performance parts. I put a helicoil in the block and a new copper exhaust manifold gasket from JEGS which shut up the leak. When we started it up it had a tick from cylinder 5, ended up scoping the cylinder, finding a piece of debris fell in on the piston, taking the driver's side head off and luckily no damage to any valves so put back on with a new head gasket after having it inspected. I also took the opportunity to put a new cam and lifters in. Ran like a champ after that.
Drove it all 2020 no problems. Occasionally I'd run out of gas in the mid-ship tank so I'd switch to the rear tank and limp it to the gas station, it ran just like this on the rear tank. I ran all the old gas out of it, filled it with new gas, dry gas, etc. no change on the rear tank, so I only use it for emergencies.
This spring it slowly developed a misfire/stumble on the primary (mid-ship) tank, and within a day or two it couldn't make it out of the valley where I live so I changed the fuel filter, it was full of rusty debris. No improvement so we dropped the midships tank and put a new fuel pump in it, midships tank was pristine inside. No improvement so we swapped in a new regulator, no improvement. During this time it stopped starting so I had it towed to the local garage. They replaced ignition module, and found a broken roll pin in the distributor, replaced with a remanufactured distributor, went back to running like crap. They drove it and set timing back to exact OEM spec as it was a little advanced, during driving it "popped and went back to running strong" so they gave it back to me. It was running strong again with a very mild hiccup/stumble/hesitation under throttle.
Shortly after that it went back downhill, I dropped the Y pipe, no change. I put a new coil, new MSD low resistance wires, new distributor cap, and new Motorcraft plugs. I wiggled harnesses, looked for vacuum leaks, sprayed ether all over engine bay while running, got nothing. I listened to all the injectors with my stethoscope, disconnected fuel lines from rail to filter and blew them out with shop air and a catch can backwards, found nothing. Checked fuel pressure and I've got 40psi, had battery and alternator tested, all looked good. Put a new MAP sensor after I found a very encouraging YouTube video, no change.
I finally caved and took it to the dealer, listed what I had done above and asked for further engine management diag. Invoice reads as follows:
"Checked and found fuel pressure in spec but when disconnection the regulator there is no change. Hooked up OTC injector tester and found all injectors buzz, found varying fuel pressure drop when cycling each injector. Removed IAC and found engine will also run better but not as it should. Advised on possible IAC issue along with injector issue. Also advised on checking cam timing and drive chain for proper installation."
I removed the fuel rail and cleaned it, looked pristine inside, nothing came out. Energized all 8 injectors with 8v and sprayed carb cleaner through both ways, shop air through both ways, new o-rings and tips (rebuild kits) for all of them. Put it back together, no change. Removed IAC and it idles high but runs strong, put a new IAC and went back to running poorly.
Please help! I'm all out of money and time.
I'm waiting on a video upload then I'll link it here.
67- Neutral safety
85- Canister purge
84- EGR vac fail
