1 - 20 of 32 Posts
The heads are refresh from JKR & has been fully PRO STOCK Porting new springs(#947 CC) , locks , retainers & seals. Also have the ARP studs. It was on a 589 with 4.560 bore & 4.500 stroke with 6.700 rod & before the PRO STOCK Porting it made 1140 HP. It ran 8.40 @ 161 with 1.20 60 ft. & weigh 3000lbs with me. any Question call me @ 440-622-9045. ASKING $3500.00 NO less , best parts are on them & the BEST worked on them. The car ran in the 1/8 mile @ 5.40 @ 130 .I have $5800.00 in these heads.
Here are the Flow
lift In. Ex.
.300 265 194
.400 335 241
.500 379 279
.600 408 307
.700 413 322
.800 421 329
Sound like nice heads! Wish I needed that much...
What you replacing them with?
Question, isn't that bore/stroke about 611 cubes?
your right I miss printed the bore it showed 4.650 when it should have been 4.560 , Thanks for noticing that. The heads I'm gonna replace with is the Blue Thunder Thor or get the 18 bolt A-460 heads because I'm going twin 88's or 91's turbos.
heads
Assume you are selling 10 bolt heads - what kind of numbers do they flow on the intake at .800 ??
They are the 10 bolt. The flow is 421 @.800 on intake & the exhaust is 329 @.800. JKR said they were looking for the low & mid lift on the intake & some gained between 20-30 cfm.
Very interested would like flow numbers and valve specs.
[email protected]
The intake flowed @ 421 @ .800 & the exhaust flowed @ 329 @ .800. JKR said they were looking for the low & mid lift gain & they gained between 20-30cfm. The Intake valves are 2.350 & the exhaust are 1.900.
Are they ti or stainless?
They are stainless & I drove this Stang on the streets & cruised 45 miles 1 way.
Are you certain you have the weight/car and hp # right?? Im coming up with 975 hp for 161 mph @ 3000 lbs??
HP
The math doesnt work out:
3000 pounds / 1000Hp = 8.40 @ 161
3000 pounds / 1140Hp = 8.04 @ 169
421 @ .800 isnt Fully Pro Stock Porting as I understand it, are you sure you got your numbers right ??
Discussion Starter #15
That is @ the rear wheel HP your getting at. Look at this web site ForcedPSI.com/calculator & you'll see rear wheel HP & engine HP.The engine was DYNOED @ Livernois Motorsport , here's the following 589 with 14.5 comp. with stock ports before porting ,276 & 286 @ .050 with .741 & .730 lift with 108 LS & single 1150 Dom. , & made 964 HP @ 6800 & 817 ft.lb @ 4800 , so I know what I have & now it had a bigger cam , 288 & 292 @ .050 with .821 & .800 lift with 112 LS & dual 1050 Dom. Also my Torque converter was way too loose it stalled @ 6600 & I needed to tighten it up between 5600-6000 stall.
Discussion Starter #16
IT might not sound right to you but I have the BILLS to show it from JON KAASE RACING , but the heads had int. port cleanup from ENGINE SYSTEM 8 years ago also these are Ford Motorsport A-460 heads & Kaase guys said they were looking for low to mid lift improvement.
We are in NO way bashing you........just when it comes to throwing hp #s out in the 1150 range, there are folks on here that live/breathe this stuff, and when #s dont add up, we get suspicious??
Mph in the 1/4 will "tell all" as far as hp power goes......you could have a bad 60 ft, but it will still mph out the back door.......
I have no doubt those heads are killer from Kaase, who comes on this site.......;)
What did the car run with the engine at 963 hp??
Discussion Starter #19
It ran [email protected] & as for the 60 ft. goes I have the 4 link @ neutral cause I don't want to use the wheelie bars. I race once awhile @ Norwalk , Ohio for Friday nite Outlaw races. Like I said the Torque converter was too loose & that probably would make up for lost HP. Trust Me , I Breathe , Eat & Sleep this stuff too & some people don't believe that I drive this car everywhere except for the people that lives around me seen me @ groceries stores & Home Depot.
Discussion Starter #20 (Edited)
1140hp?? My C-headed deal only makes 1132hp so I must be doing something wrong!!
I have a friend that make 1226 HP with C-heads that Engine System built for him & that was a single Dom., & they told him to do a Tunnel Ram would get close to 1300.
1 - 20 of 32 Posts
