I have a set of A429's Im thinking of selling. I havent taken them off the motor yet.
The come with
2.25/1.76 or 2.19/1.71 stainless valves (I cant remeber for sure but will verify)
pressed on stem seals
Moroso studs and 5/16" guide plates
Comp Cams 1.72 roller rockers w/ posi locks
.650 lift springs w/10* steel retainers and machined locks
Trickflow hardened, thick wall 5/16" pushrods for SCJ's
I will also include the Herbert .620 solid lifter cam w/lifters
Heads are gasket matched to a SCJ gasket. Heads never hurt or decked. this combo went 10.70's on the motor and 6.70-6.80's all day on DR's
Looking for $1500 for everything
Thanks Casey
Jim D. Which Wieand Stealth do you have? If you have #8012, it's for standard port heads - it will fit, but huge port mismatch. The Weiand Stealth #8021 is made for CJ and SCJ heads. Hope this helps.
Wayne (SAWDOFF) Pearce
