1 - 14 of 14 Posts
Another season has come and gone. Selling all my A460 Stuff. PM me if you're interested. Thanks 460Ford.
:arrow: TFS A460 Cylinder Heads - $2695 - SOLD
Manley +.100" Titanium Valves, 1.650" Nextek Springs, and Titanium Retainers.
Int flow = [email protected]", Exh Flow = [email protected]" w/ 45* valve job.
Int Valve = 2.350", Exh Valve = 1.925"
Setup for dry manifold.
:arrow: Jesel Shaft Rockers for TFS A460 Heads - $1000 - SOLD
1.8:1 ratio Int and Exh.
:arrow: Billet Fabrication Aluminum Valve Covers for BBF - $150 - SOLD
:arrow: Garrett Cast Magnesium Valve Covers for BBF - $150 - SOLD
:arrow: Manton 7/16" Tapered pushrods, .165" wall, Int = 9.270", Exh = 9.600" - $150/set - SOLD
:arrow: Comp Cam - $150
Grind #: FF 328R-5 /348R-1 SR114.0
[email protected]: Int = 328, Exh = 348
Lobe Lift: Int = .477, Exh = .460
Lobe Centerline = 114*
:arrow: 4.50" Forged Steel Crank - $1000
AMS 6415 SVO Forging ground by Henry Velasco.
2.200" Rods, 3.00" Mains, Std
Standard BBF Snout
Ready to install
:arrow: BHJ Balancer w/ Aluminum Hub - $150 - SOLD
:arrow: Wiesco TFS A460 Domed Pistons - $450
For a 4.625" Bore, 4.500" Stroke, 10.296" Deck Ht.
.043" Compression Rings, 3mm Oil Ring
.990" Pin
.100" Dome
9 available, 2 are .005" oversize
:arrow: Hooker Headers, Custom Built for A460 Head Engine in Tube Chassis - $495 - SOLD
Built by Smiley, 2.375" to 2.5" Step, 5" Collector, Black Jet Hot Coating
Used for one season, perfect condition.
the billet covers. do they fit all 460 style heads, or do the a460 have a special bolt pattern.
Please send pics to balistic @ mchsi.com
Thanks Dave
Brian_Eyler - PM me with your email address and I'll get you some pics of the Garrett VC's.
Dave Max - I beleive all the 385 series Ford covers have the same bolt patterns. These covers use 6 bolts (the top center bolt isn't used)
whtstdhrse - There are approx 30 passes on the rockers and only 20 of them are full passes. Less for the pushrods... maybe ten. All are in perfect condition.
TravisRice - I'll get some pics of the VC's and send them to you Thusday.
Darrin Gorham - You've got a PM
Just got the jeselrockers and 7/16 pushrods in the mail I bet they add 20lbs to the motor over the roller rockers 3/8 pushrods
4.625 pistons
Do you still have the pistons available? I assume they are for the 4.5 stroke crank if so, what lenth rod? thanks---David F.
Discussion Starter #14
Dave 61 - I do still have the Rods and Pistons. The pistons are for a 4.5" stroke, and the rods are 6.8" long, .990 pin, 2.200 rod journals.
Jon - That's a stout rocker system, no doubt. The weight is all in the stands, the rockers themselves are probably similar to a typical roller rocker.
1 - 14 of 14 Posts
