1 - 3 of 3 Posts
Less than 100 miles on it, swapped it out for a Holley twin dominator EFI pump. Ran fine, quieter than my other A1000 pump and its good for 800hp. Has -10AN inlet and -6AN outlet and good for 80psi max. Comes with everything that came with it, mounting brackets, fues holder, wiring stuff.
asking $140 plus the ride.
Discussion Starter #2
I guess I should also state... even tho the pump is an EFI pump and can operate at high pressure it can also be used for carb applications, can be used with a return style regulator and will support more HP under carb application. So if it's able to support 800hp EFI it should be fine for 1000hp carb. It's a quiet pump compared to a holley or aeromotive and can support more psi if u need it for like a nitrous system or even more PSI for hard launches.
1 - 3 of 3 Posts
