Status
Not open for further replies.
AFR Top End Kits:
--We supply the parts, you supply the labor
--All the same parts we use to build our engines in-house.
--Custom spec'd to your application.
--Compatible with SCJ pistons in some applications
-AFR Bullitt cylinder heads - 280cc, 295cc, or 315cc ports - 75cc or 85cc chambers
-AFR aluminum intake manifold
- 4150 or Dominator flange
-Lunati camshaft - hydraulic or solid - flat tappet or roller
-Lunati lifters - hydraulic or solid - flat tappet or roller
-Lunati billet 9-key double roller timing set
Starting at $2799.95
Piston notching tools, roller rockers, pushrods, valve covers, carburetors, etc. also available
Please call or email with questions
Top End Kits
AFR Top End Kits:
-AFR Bullitt aluminum cylinder heads - 280cc, 295cc, or 315cc ports - 75cc or 85cc chambers
Top End Kits
Ugh...where was this when I was looking?!
Sent from my iPad using Tapatalk
Status
