1 - 7 of 7 Posts
I have a few question on running Alcohol.
What is pros and cons?
What compreshion is needed?
Are cam profiels differnd between Gas and alcohol?
Is there a large gaine or Gas using a carb?
pros...cheaper more tourqe(??) burns cooler (burn me down suker!!!) did I say CHEAPER!!!!!
cons absorbs water & is more corrosive!!! needs a good top lube!!
I have rum it with as low as 8-9 to1 BUT the more the better!!!!!!
not really different just need to allow for more "wet" flow
??????????? I have used methanol with a carb & injected!!!
any more questions???
I belive I will get a 850 set up for it and give it a try running 12.5 to one so it should like it.
1 - 7 of 7 Posts
