1 - 15 of 15 Posts
these parts are for my friend who's clearing out alot of parts.have alot pics of these items also!
• Flowtech headers 86-93 V8 Mustang 1 ½ diameter shorty. $80.00
• Cobra Jet rods (7) ARP bolts/resized. $80.00
• Speed-Pro pistons (7) H535P .060 Hyperutectic. $80.00
• 351 Cleveland engine only. $3300.00
• 1977 F-150 truck, 460 V8, C-6 trans. $1100.00
• 1978 Mustang II DRAG CAR NEVER RACED(complete car w/motor,trans,rear,eletronics). $5500.00
• 1984 351W H.O. $400.00
• 1991 5.0 H.O. Engine, forged .030 pistons, eagle rods, arp head studs, 40,000 miles. $850.00
• C-4 trans separate from Mustang II, PA performance trans brake. $650.00
• TCI Torque 8” Convertor (NEW), 5500-6000 stall speed. $500.00
• Complete 1986 5.0 roller engine. $530.00
• 1978 9” rearend housing with axles. $80.00
• 9” rearend from 1978 Mustang II, built by Pyle Bros., 33 spline Moser axles with full Strange spool, 4.57:1 gears, disc brakes. $820.00
• 1982 Small block C-6 trans. $115.00
• Exhaust from 1979-1993 Mustang with BBF (429/460). Complete H-pipe from header flange back to Flowmaster mufflers with Dr.Gas X-Pipe. Headers are Hookers for BBF in 1979-1993 fox part #6224. All for $500.00 $300 FOR HEADERS.
• 1978 Long Tail C-6 transmission. $50.00
• TRW forged .040 pistons L2219F for 1965-1969 ONLY Ford inline 300 6-cylinder. $100.00
• Nitrous Works 11010 system w/purge. $300.00SOLD!
• 429/460 Offenhauser Port-O-Sonic intake. $170.00
• 1986-1993 Gripp Strut tower brace. $50.00
• 1977 460 Short block, (7) cylinders are perfect and will stay standard. One cylinder needs sleeve because of bad piston. Crank is perfect.
• M-12579-L54 90mm lighting mass air meter w/plug to connect directly to 86-93 EEC IV system. $110.00
• BBK 65mm EGR spacer and Throttle body for 1986-1993 5.0 Mustang. $160.00
MUSTANG II
IT'S A DRAG CAR WITH A 351 CLEVELAND 12.0 -1 COMPRESSION,ROLL-CAGE,C-4 WITH PA PERFORMANCE BRAKE,TCI 5500-6000 STALL NEW,LINE-LOCK,SWITCH PANEL,GAUGES,SHIFTER,RACE SEAT,5 POINT HARNESS,FUEL CELL,REAR MOUNTED BATTERY,9 INCH REAREND WITH DISC BRAKES,457 GEAR ,FULL SPOOL,33 SPLINE MOSER AXLES,WELD DRAGLITES,AND MORE.THIS CAR HAS NEVER BEEN RACED.HE HAS MORE IN THE ENGINE THAN HE'S ASKING FOR THE CAR BUT HE MIGHT PART IT OUT.I HAVE A DOC. WITH ALL THE ENGINE SPEC'S AND WORK IF NEEDED.
quote="TorinoStyle2"]$5000 for a Mustang II?? :?[/quote]
Rear end
What's the axle flange to axle flange width on the Pyle Bros rear end? Are the axles five lug or 4 lug? Is it ford disc brakes, or aftermarket? Is this a spare rear for the MustangII, or is it currently in the car?
Thanks,
James
Re: exhaust
chevetr said:
"Headers are Hookers for BBF in 1979-1993 fox part #6224."
Would you sell the headers seperate? how much? thanks
he wants to sell as complete system but i'll ask him.
Discussion Starter #14
Re: exhaust
he wants $300 for the headers.
Discussion Starter #15
Re: exaust
steve skinner said:
i would be interested in the rest of the exaust if its 3"
thanks,
steve
the exhaust is 3'" down to the dr.gas x-pipe then 2.5 to the flowmasters.
1 - 15 of 15 Posts
