looking to find an alternator bracket(s) for 460 with moroso electric water pump. Any info much appreciated. I don't mind buying a new alternator too as long as it's a single wire unit. Thank you.
New prototype at the pri show.
Look's similar to blake's modified victor intake a few years ago!!
https://www.facebook.com/photo.php?fbid=10157432403986953&set=pcb.2232513893517392&type=3&ifg=1&__tn__=HH-R&eid=ARAUyDnqHiG8OhiRChcpf2y2R9MA3kYRRB85NEk-U8J9YkxjcVIhQEatKRzBoyKnxuCLG5krxmvGRlTD...
Blew anothet head gasket took .006 cut to clean heads. Have been running felpro 1018. Thinking of changing to felpro 1028 which has steam holes...any thoughts? .30 over with scj heads ,probe pistons scat forged rotating assembly, lem's grind comp solid cam,
I'm building my 91 efi 460 a d with how I'm building it, I expect it to make at least 500 ftlb at the crank with around 380 hp. I have a c6 tranny in it and I looked it up, the stock c6 transmission is rated to 475 and considering it has 320k miles on it, I'm a little worried it would destroy...
All,
I have a 521 that was built a couple years ago and I currently have it torn apart to discover what the engine builder had actually done vs. what I asked for. Im currently looking for cam timing recommendations for this combo. It will be going in a 1970 Torino with a C-6 and 3.91 gears...
