Next Topic >> Return to Index
Aluminum Rod Question
January 9 2006 at 10:30 AM
No score for this post James (Login James598)
from IP address 148.104.5.2
What brand aluminum rod is recommended?
Author Reply
waterslinger
(Login waterslinger)
192.91.147.34 Re: Aluminum Rod Question
No score for this post January 9 2006, 10:33 AM
I use BME with good results.
438ci Big Block, 2 Speed J.W Trans. W/ 4800 Stall, 9" rearend 3.89 gear, 4-Link suspension,
1/8 mile 5.83 @120mph
http://www.geocities.com/ryan98gt/fordzilla
http://www.geocities.com/waterslinger1
David Henderson
(Login BigBlockTbird)
216.215.227.182 Would you elaborate....
No score for this post January 10 2006, 11:51 PM
on your experience with using BME rods? How much use you have you gotten from a set before replacement was necessary? I read so much conflicting info on aluminum rods in general. Not all aluminum rods are the same. I know BME's are forged, not billet, which is a plus and they are now made of a material with more fatigue life than the previous 7075 matl. Just looking for someone's real life experience with this particiular rod. Thanks.
waterslinger
192.91.147.34 Re: Would you elaborate....
No score for this post January 11 2006, 7:55 AM
Motor guy said 200 runs are safe. NEVER let the motor pull the car down.
from high gear to N as you lift
c.perry
(Login 86dragbird)
207.4.125.78 Re: Aluminum Rod Question
No score for this post January 9 2006, 11:54 AM
A truckpulling buddy of mine uses GRP.
If I should ever need blood,................I take Type "F". Chris
Rob
(Login 67stang1)
216.203.18.200 Re: Aluminum Rod Question
No score for this post January 9 2006, 12:05 PM
I've used Super Rods & Brooks with good results. I think next time I'm going to try Childs & Alberts deep cycle rods.
DaveMcLain
(Login DaveMcLain)
64.251.140.229 Aluminum Rod Choices
No score for this post January 9 2006, 2:13 PM
There are many good aluminum rods on the market today. In my personal experience I've used mostly the BME's with great results. I've also used the Manleys again with no problems.
James
(Login James598)
148.104.5.2 Thanks for the responses
No score for this post January 9 2006, 3:35 PM
I've got a brand new set of Brooks 6.8's that haven't been run but I think I'm going to have to go to 6.7's to get the compression ratio where I want it...that's why I was curious as to what everyone else was running.
Craig
(Login SQ34)
65.26.177.221 Oliver
No score for this post January 9 2006, 6:39 PM
Steel Billet Rods and never replace them.
