Just found this forum. Have a 71 F100 with a worn out 390 which i plan on replacing with a 460 i got from an "89 E350 which one of my workers totaled. First time in modifying a fuel injected engine. Id like to keep it if it can be used as its so much easier to deal with than a carb. Ill be keeping the c6 as the truck currently has the 4 speed t19 which is tough but clunky.
Id like to modify the engine some but i want to drive this daily.
Modifications and factory EFI can be a sticky situation. Scott Johnson “The Mad Porter” has a few towing engine packages that will give you an idea of what power and torque is possible with the factory EFI. You may want to send him a PM.
