If I run the adjustment screw on the vacuum advance on my stock duraspark dizzy all the way in and all the way out, I'm only seeing about 3-4 degrees, tops, change in the timing. Is this all of the adjustment there is.
The engine runs great. I'm just trying to remove a tiny bit of detonation on light to medium throttle acceleration. My static is at 7 deg.
This isn't an issue except during the peak heat here in Phoenix.
All I probably need is a couple more degrees.
Anyway, is that really all of the adjustment available?
Thanks,
Tom
Thanks,
Tom
