Hi ., new to the forum ., I could use Any advice or help anyone may have ..
I’m swapping a 69 Lincoln 460 onto a 73 Torino … the issue at hand seems to be the 1) clearance of the front sway bar and crank pulley
2) the oil pan not allowing the motor to sit lower on the cross beam to allow for Tranny bell housing clearance to install the transmission.
any ideas if there is a different oil pan set up to accommodate or any other ideas at this point would be much appreciated..
thanks
thanks
