Im having a very hard time getting my shifter adjusted. I want to make sure im trying to adjust it to do what I want. Its controlling a c6.
Pull lever all the way back for 1st.
Bump to get 2nd gear.
Squeze trigger and hold to go to 3rd.
Release trigger once trans is in third and you can push to neutral.
Squeeze trigger and press Reverse lever for reverse and continue to hold trigger for park.
Is that correct. If not please tell me so I can get this thing figured out.
The lever action is correct as you describe except you do not have to squeeze the trigger for reverse, just push the reverse lever and the shifter into reverse. The instructions are downloadable in pdf form from the B&M website.
