1 - 10 of 10 Posts
I found a 1974 30' Trojan Flybridge for sale. The stern sank in the slip during Hurricane Katrina and the engine compartment flooded. The interior got some water, it wasn't entirely flooded. The owner has redone the interior cabin, etc... All he says it needs is to have the engines rebuilt.
It's got (2) 351W's in it for power. He says it doesn't leak water, just a little seapage past one of the rudder posts. It's got A/C, Gen, he says the electrical is in good shape, etc...
It's a brackish/salt water boat so I'm sure the cooling system will need a good going through. Maybe new tube/shell coolers, pipes, manifolds, etc...
He's moving soon and can't take it with him. I'm hoping to look at it sometime this week.
What's your thoughts on this? How much would something like this go for? How much do you guys pay per month for a slip at the marina or boatyard, annual maintenance, etc...
I've always wanted a "big" boat. I like the idea that I can take the kids out on it for a overnight trip, etc...
Just a thought.
I'm far from an authority on boats but I worked with a couple of guys who had good sized boats, one owned a Trojan. The other guy had a Carver, and he seemed to know a lot about boats, and he told me that Trojans have a shallow hull that makes them fast but they are not too stable in rough water. Other than that he said Trojans were good boats. Just an observation.
John -
I had a 45' Hatteras ("The Hooker") for several years; probably the dumbest thing I've ever done, but I'd do it again. I paid $70k for it in 1996 and had it chartered out in Grand Isle and then Fourchon. Had a captain and deckhand that ran the boat and someone to book the trips; trying to break even and get the boat to pay for itself, but that didn't quite happen. Sold it in 2000 or so.
Boat took on water one day and the engine compartment got flooded. Engines were good, but generator, starters, alternators, and much of the wiring had to be replaced. Boat had a pair of 6-71s and starters and alternators aren't cheap. I would figure on replacing just about anything that carries an electrical current if it got wet. You don't want to risk having something short out in the engine compartment, especially with gas engines. If the generator got wet, you'll need a new one; see if you can find a good used one.
I was paying several hundred a month for a slip, I think, but I forget exactly how much. Maintenance was another issue - I was charging $1,000/trip, and after you took out fuel cost, captain and deckhand pay, the rest was eaten up by maintenance. Boat was a 1971 model, I think, so it's age contributed to that.
A few more thoughts - "freak accidents" seem to happen quite often, so be prepared. I can remember running up the Mississippi one night headed to Venice, against the current, no steering (was steering with the throttles), no lights, and one transmission about to go (that would have killed ability to steer with the throttles), dodging cruise ships and crewboats, etc. Definitely a white knuckle ride.
Also, a boat that works perfectly well when moored after a trip will develop several problems while sitting at the dock.
Ok, I guess that's my $.02. Bottom line is that it doesn't sound like a bad deal, but be prepared.
Scott
D
Guest
I just picked up a 73' Chris Craft Commander with 2 x 427 ford marine engines here in Seattle.
$3-4k sounds like a good deal as long as it a Fiberglass boat, Stay away from wooden haul's.
Have a Survey done by a pro, usually costs about $300-$400 + haul out.
Typical Morage in my area is $7-$10 per foot.
Nothing to hard about rebuilding some motors, the low performance boat stuff is no bid deal. But expect parts to be $$$ as soon as you say BOAT or Reverse Rotation.
Just keep in mind maintence is an ongoing thing with salt water boats and you will need to spend some time with it to keep it nice.
Guys,
It looks good from across the water. haven't been onboard yet. Thanks for the heads up. If I can get it fairly cheaply we'll see. My biggest concern is trying to get it hauled out and checked over...
it's all lass. Hull, decks, etc... Not sure of shapoe but it's definitely glass.
D
Guest
John,
Find a couple of local marinas, they normaly have haul out facilities and contacts for people to do the inspections.
John -
There is an older guy who surveyed my boat - very honest - his first name was Cy or something like that. He was at the marina in the lakeside area across the street from where all the sand volleyball courts are.
Anyway, haul out and survey is money well spent. I had a 48' Egg Harbor wooden boat hauled out and surveyed and ended up passing on the old girl. You can also use the faults found on the survey to further negotiate with the seller.
Good luck,
Scott
I laid eyes on it today. It wasn't even worth my time..... Real bad repair job from the water damage. It went waaaaaaay under too during the storm.....
1 - 10 of 10 Posts
