1 - 10 of 10 Posts
I'm using the old layout and the auction block isn't updating. The tab shows that there has been new activity and on the header it shows a new topic but when I go into the section it still shows the old items. Right now the new item is about a Kaase oil pump but it's not in there when I open the page it shows *WANTED* BBF FOX BODY STUFF, or something like that.
Also try sorting on the "Last Post" date so it will reset with the most recent as the first listed.
Jeff
Tried that also, not working.
Each time I visit page I seem to have to reset everything.
Just want to be able to open page & see latest posts up.
Thanks Steve
Thanks Steve
X 2
Thought I had it figured out, but it does the same thing now..
Have to reset everything every time and sometimes that doesn't work..
I am having the same problem with not only the Auction block, but with both the Engine Tech Archive and the General Tech Sections. The other sections seem to be working correctly.
Community Manager/Admin
Heya guys,
If you are having issues with viewing the auction block please check the settings at the bottom of the page.
See attachment:
At the bottom of this page you can sort and trim the list by date.
The Auction Block - 460 Ford Forum
Thanks,
Jeff
1 - 10 of 10 Posts
