1 - 18 of 18 Posts
added a moroso 4 vaine vaccum pump- changed some suspension stuff- :D
ive left timing and carb alone - will mess with that at a later day- im looking for a 9:60 ish pass as long as she hooks
if the car hooks like a 1:35 or better the car should run 9.50 s will keep you all posted -remember this is on a 315 x 60 mickey drag radial :lol:
well the day didnt start out so great- miss read the web site - showed up 5 hours early ,wasnt going home
well track wasnt hooking at all- 3 1.78 sixties all in the 10.40 range
swiched lanes came up at about 2500 rpm - car went
9.63 @ 144 with a 1:47 60ty and 115 in the 1/8 all motor
that track is garbage - kevin ask them to spray the track and the kidd said just do a better burn out and she will hook-
so we are getting there - radial are gone switching to a better tire
29.5 x 10.5 W
Hell Mike D said the M/T radials work better than slicks most times.
May just be the track, the heat dont help eihter.
By chance have a video of the launch? Could help get a look at whats going on.
S
Guest
Very nice progress Gerry! Anyway to post the run data??
Keep going your doing great!
Also would be cool to see some pic's from the track..
Les
Gerry,
9.60's is pretty good for the 60 ft. you had,it was also hot and humid out.I think with a better 60 ft. and cool weather 9.40's should be no problem.What track did you go to?
Later Mark.
Gerry,
I thought you weren't going back to Quakercity.It either seems to be real good or real bad.My good friend had his car there Friday night.Larry Reese was there about 3 weeks ago and had a 1.28 60 ft. then it rained and they cancelled the race.
Later Mark
1 - 18 of 18 Posts
