· Premium Member
My old ballancer was about 6.5 OD , I have seen a couple new ones one is 6.65 and the other is 6.8 OD The first one is closer to my orgianl but is The OD critical? These sholuld both work the same on an internallly ballanced motor ?? This Is the second time I posed this question . I know it is not a very glamerous topic ,but I sure would appreaciate some response. I am raedy to order the Balancer but I need a little advice . Thanks Rich
Author Reply
Lem Evans
(Login l-evans7)
69.166.129.47 Re: Balancer Qusestion
No score for this post December 9 2005, 7:12 PM
Question ? What HP ,stroke , RPM , etc .
The answer may get you some responce .
Rich
(Login godzillatorino)
207.200.116.200 Ballancer
No score for this post December 9 2005, 8:25 PM
The Engine is standard stroke 466, With forged pistons, about 9.6 to 1 Compression, Ford Motorsport Solid roller cam , HP estimate is 500-550 HP , RPMs about 5800-6000 ,no more than 6200-6300. Nothing special beyond the roller cam and ported Dove C Heads.
Lem Evans
(Login l-evans7)
69.166.129.47 Re: Ballancer
No score for this post December 9 2005, 8:41 PM
I like a damper that is more or less stock dia. 7"ish if for no other reason the timing pointer is not 1/4" {or more} away from the O D of the damper .
At your RPM level and stroke...there is a lot of stuff that will get it done .....anything that is better than a brand new 1970 SCJ unit , IMO .
Rich
207.200.116.200 Hmmm? My Stoker Was 6.5ish
No score for this post December 9 2005, 9:07 PM
So The 6.8 SFI one that I like will probably do the trick?http://www.texasperfparts.com/store/scripts/prodView.asp?idproduct=205 The one a saw in 6.65" only came in chrome , My motor is cosmeticaly not a flashy deal, Very minimal chrome no polished aluminium ect ...Gloss black engine enamal and as cast Victor Intake and Edelbrock Alumnium waterpump.
Lem Evans
(Login l-evans7)
69.166.129.47 Dia.
No score for this post December 9 2005, 9:14 PM
looks good...is it better than a stock 1970 model ?....ain't no way to know .
Rich
207.200.116.200 better than used
No score for this post December 9 2005, 9:18 PM
Its gotta be better than my 35 year old balancer. AQnd the SFI rating has got to mean something Right?
