1 - 6 of 6 Posts
BBF Lunati cam,lifters,springs REDUCED to $100
BBF 429 460 Lunati Bracket Master II solid flat tappet cam part# 41607 with lifters and springs. .603/.609 lift, 265/272 duration @ .050. Has a total of 11 passes on it, nothing wrong with it just built a bigger engine so I'm going to a roller. $100.00 for everything and I'll ship! Travel for work a lot so the best way to contact me is PM through 460Ford or e-mail [email protected], I check my messages daily. Can e-mail cam card if you would like.
Sure I'll seperate the springs, How does $50.00 + shipping sound?
Spring specs:
Part# 73121
Spring Type: Dual w/damper
Outside Diameter: 1.540 in.
Inside Diameter: 0.794 in.
Seat Load: 142 lbs @ 1.940 in.
Open Load: 402 lbs @ 1.250 in.
Coil Bind: 1.130 in.
Spring Rate: 377 lbs/in.
Let me know.
Tim
1 - 6 of 6 Posts
