1 - 3 of 3 Posts
I have a 501 BBF short block for sale. It is 4.150 stroke with a 6.8 rod and 4.390 bore.
- 79 block with all the machine work done
- Diamond flat top 4.390 pistons cut for new style SCJ heads
- Eagle 6.8 h-beam rods with ARP L-19 rod bolts
- Ohio crankshaft 4.150 stroke 4340 crank
- Ford Motorsports oil pump and shaft.
- Comp cams roller cam and lifters
- Comp cams timing chain set
- Milidon windage tray
- Clevite main, rod, and cam bearings.
- All internally balanced.
Engine only has 20 passes on it since it was new, everything is in great shape. the only reason for selling is i am going to a smaller cubic inch motor to meet more of the local rules. $3000.
I am located in Ames IA 50010. I have pictures i can text you, call me at 515-290-3104.
1 - 3 of 3 Posts
