1 - 16 of 16 Posts
ELIMINTOR ULTRA BLOCK, BRYANT CRANK, NEW GRP ALUM RODS, 14.5 COMP, ROSS PISTONS, 4.625 BORE, COMP ROLLER W/CRANE ULTRA PRO LIFTERS, JESSEL TIMING BELT, KASSE SCJ HEADS 390 CFM W/JESSEL ROCKERS 1250 DOMINATOR, TITAN OIL PUMP W/STEFS FRONT SUMP PAN 975 [email protected] 843 FT [email protected] HAVE DYNO SHEETS RAN [email protected] IN 3,350 LB CAR. MOTOR BEING FRESHEN NOW,WILL BE AVALIBLE IN FEB 08.........CONTACT STEVE 301-672-6429 OR AT [email protected]
BBF 605
I might be interested in the short block. I guessing thats a 4.5 stroke. Are the pistons, domes or flat tops? Are they pistons for thoses heads? I will be running A460 heads and they require valve reliefs for their application. If interested, give me a price on the short block.
bbf 605
yes the stroke is 4.50 the pistons are domes and for the scj heads the short block oil pan and titan pump 9000.00 thanks steve
BBF605
I guess I'll pass. The only thing I can really use is the block and the crank. The pistons won't work as I'm running A460 heads and I really don't want aluminum rods. If your willing to separate I would be interested, but I understand if your not.
have a price in mind for the whole motor? and your location?
bbf 605
im asking 14500.00 for engine that is carb to oil pan straight from the machine shop zero runs on freshen up thanks steve 301672 6429
bbf605
i would like to correct the block is a premier block not a ultra like it was stated before thanks steve
1 - 16 of 16 Posts
