1 - 14 of 14 Posts
For Sale: New (assembled on engine but never run) Blue Thunder aluminum cylinder heads with Chevy exhaust ports. Comp Cams springs, ti retainers, locks, and mechanical roller lifters. Ferrea s/s valves. T&D custom shaft rocker system (1.75:1 ratio). The rocker stands have been doweled to the pad for alignment, not welded with steel straps. ARP head stud set. With 10.300 deck height and JE flat-top pistons, the comp ratio is 14:1. Springs are installed at 1.960 with 240# seat pressure.
Comp Cams
Springs #998-16
Ti Retainers 733-16
Locks 611-8 exh
614-8 int (+.050")
lifters 836-16
Spring cups 4702-16
Ferrea intake valves F-1212P 2.250 (11/32)
exhaust valves F-1401P 1.800 (11/32)
Heads can be disassmbled for inspection $4000.00 firm
Skip Ohnmacht
(315) 343-6030 M-F 8am-5pm EDT
(315) 343-3666 eves and weekends
If you get voice mail, leave your name and number. I return calls.
1 - 14 of 14 Posts
