1 - 3 of 3 Posts
H beam rods 6 Manley 2 Eagle balanced to a set, Used .990 pin BBC rod 6.7 long $150
Aluminum rods Howards 6.7 long .990 pin BBC rod Used don't know history got in a 521 motor $200
Turbo 400 with Bake deep pan ,shield $900
Roller cam New Comp Cams I .796 lift 285 dur. E.726 lift 288 dur both @ .50 $200
Stud Girdles New CAT with long locks for stock valve layout $60
7 J & E pistons for 501 4.150 stroke 30 over small domes flycuts for stock valve layout $100
Blue thunder chevy port heads small chamber one hurt bad heads are complete $1000
Several conveters all turbo 400 splines 1- Coan high HP sbf 6000 stall $300 redone TCI sbf
6000 stall $300 coan 5000 stall for 501 ford $400 turbo input
Holley 9375-2 Dominator as new $600
Moroso 760 15 fronts $150
All plus the ride
If you want pic send me a direct email
Denny 330 842 1886
1 - 3 of 3 Posts
