1 - 9 of 9 Posts
Built up my first BBF for a 18ft jet boat. Currently turning "A" cut impeller 4800 rpm and according to Berkeley HP chart says my engine only makes a whopping 350HP. Stock BBC boats are faster than me... I bleed blue but damn those Chebies boys are making me look bad. Below is my build parts am I way off on power or a totally mismatched setup to blame please any help would be appreciated.
  • 466ci
  • Dove heads rebuilt/ported following reincarnation excellent instructions
  • Claysmith cam In/Ex Duration 280, @.050 231, In/Ex lift .565
  • slugs in hole .020 with -22 dish pistons guessing 9:5:1 compression (running 91 and spark plugs look great)
  • stealth intake with old 750 vacuum secondary carb
  • kasse oil pump
  • rotating assembly balanced
  • arp hardware
  • scorpion rollers
  • log style manifolds
  • 35 degrees ignition timing
Engine runs really smooth. I was thinking about throwing a 850dp at it and a performer air gap intake.. maybe headers but guys big block ford's are EXPENSIVE AS HECK lol I built a 331 stroker with afr heads for a 68 mustang and its a ripper but this BB seems anemic.. maybe if this engine was in a car it would be a ripper too. Opinions please
I read once that boat engines 460s like a 108 LSA? What is yours? Also with exhaust manifold it might cause alot of reversion upstairs and cause it to go lean, try jetting up carb about 4 jet sizes. Also with reversion it might need more total timing. Get some header!
Discussion Starter · #3 ·
Cam card says 110 LSA. Called Nick at Claysmith Cams and he strongly suggested a larger carb and degreeing the camshaft.. said my combo should make 500hp but this is hard to believe. To be honest I haven't played with the carb and i'm totally thinking about headers but the kiddos freak me out around them.
What ignition setup are you currently running?
I assume it’s a berk pump. Do you have any pump mods? Loader, shoe, ride plate etc?
There’s more to finding mph in a jet than just throwing more hp at it.
That single pattern cam is killing your top side.
Logs are not helping matters either.
"EMC 2006" 3rd place finisher
Custom ground cams
Customized crate engines
ParklandAutoMachine.com
R-H-P.biz
(253)-988-6648
Log In or Sign Up to View
Discussion Starter · #7 ·
I upgraded to a FST mechanical 850 carb and new tachometer now boat only turns 4400 rpm @ 60 mph which I am happy with. After this boat season I want to try a new camshaft set up though. The mad porter if you can supply one for me that would be great, what duration and lift would you suggest.
I think you may have better luck contacting him thru a PM here or calling the shop so youse guys can put y'all's heads together on a custom grind. Scotty is a really great guy to work with and will get you straightened out with what your boat needs! I do agree with him, that single pattern cam is really killing it. A dual pattern cam leaning heavy on the exhaust side is what these big block Fords need to breathe...
1 - 9 of 9 Posts
