What are you all using for transmission mount/cross member with a C6?
this is the one im usingWhat are you all using for transmission mount/cross member with a C6?
you have the weird long tailshaft c6 ? i had to buy a short car shaft and tail housing to have the standard 2 bolt trans mount like the factory cross member uses, but i had to tear the trans all the way apart to change the main shaft ?that is the cross member in the car as it was a 5-speed car. what about for a mount? just any old trans mount? mine is out of a '76 Thunderbird, just get the stock trans mount for that?
It probably isn't nearly as complicated as I am thinking as I only seen it through the shifter hole. just looked crazy having the mounting holes on the trans at an angle on both sides then the trans member straight down and what not.
