501 rotating ***. by BME 30 over pistons 6.7 rod 4.140 stroke with speed pro rings, new, h beam used rods and BME ground oem style 4.140 crank not run. $800
Precision Plus 3 speed air shifter with cable, floor brackets, neutral safety switch and 2 set point rpm switch $500
Canton 7 qt front sump pan & pickup $200
Desiderato performance aluminum pan , dragster style with pickup & high pressure pump $500
750 Holley vac secondary no choke $100
OEM style sfi approved balancer $50
a460 stud girdles with long poly locks $50
Victor intake dominator flange for cj heads $250
All + the ride
Denny 330 842 1886
