Status
Not open for further replies.
1 - 11 of 11 Posts
BBF Parts and More SOLD
:laugh:Decided to go a different direction -- Need space in my shop!
BBF Rotating Assembly $ 850.00 sold
Includes - Stock Offset Ground Crank, JE SRP Pistons 80 over with 9.90 Pins and 6.80 Brooks Aluminum Rods
SOLD -Comp Roller Lifters $ 100.00 - SOLD
SOLD - ARP - Engine Accessory and Fastener Kit(NEW) - $ 75.00 -SOLD
Stock Front Sump Oil Pan $ 25.00
Hurst Quarterstick (used one season) - Rear Exit $ 150.00
NOTE - Has aftermarket line lock knob (missing red button)
works fine and has 20 or less passes on it. Will not interchange in both of my cars is only reason for selling!
JEGS PART # 530-316-0020 retails $ 259
SOLD -B & M Shifter $ 100.00 - SOLD
SOLD BBF 4-Speed Bell Housing $ 75.00 SOLD
Contact Dale - 660-651-8580 Call or Text
Can send pictures if you text or call and will try to get them uploaded.
If there is something you need that isn't listed -- I may have it!
Factory 2y crank offset ground to 4.150 stroke, the piston are srp .080
flat tops for standard valve location,they have intake valves and exhaust relieves and are newThe .6.8 Brooks aluminum rods are used I got this stuff in on a deal.
I have attached pictures if you would like more pictures contact me
1 - 11 of 11 Posts
Status
