1 - 7 of 7 Posts
Fluid dampner $300
Dixie 3 speed reverse pattern air shifter with air bottle & cable no rpm switch $250
A460 stud girdles SAT SG-6001b new in box with long polylocks $60
Accell electronic trigger distribution with brass & steel gear $ 100
526 short block fresh aluminum rods gas ported pistons roller cam & lifters short snounted crank to sbc set up for external oil pump block filled to water pump holes $4000
Iron cobra jet heads Dooe-R with valves Jessel 1.7 rockers & stands & pushrods never hurt
$2800
Dove 173 used rockers excellent shape $150
All + the ride
Hope to be in Columbus this weekend can bring parts there
Denny 330 842 1886
Do the poly locks come with the rockers? What size shaft do they fit? Do you know what brand they are?
Thanks D
If you still have them and they will fit my heads, I would be interested in the stud girdles and locks. I have the trick flow 325 powerports. Dont know if they will fit.
stud girdles
The girdles are tentatively sold waiting on the money order, and they are for the A heads. I believe your power port heads have stock valve locations so they would not work for you.
Denny
1 - 7 of 7 Posts
