1 - 7 of 7 Posts
****SOLD****Eddy heads 96CC with valves 2.25 int 1.760 exh flat tapped springs (need to be assmbled) comes with head studs/guide plates/rocker studs ported by (MADD Porter) supported 730+ HP to the ground ****SOLD****
Offenhauser port-O-sonic 4500 flange have adapter to 4150 drilled ports for injection but currently plugged off/Also comes with 4500 to 4150 adapter $200
****SOLD****Accusump oil accumulator with electric pressure valve (Used purchased from member not needed) ****SOLD****
Kasse oil pump with studs used (going external pump) ****SOLD****
Offenhauser Tunnel ram setup Hat injection but can have plate welded too for 4500 carbs $250
Cleaning out garage.. All parts are plus shipping and best reasonable offers.
PM if you need pictures
Thanks for looking
Chris (AKA TOPHER)
What cam was used to make 730 plus to the ground. A solid flat tappet or roller. Also was this a flat top motor and how much compression. Thx.
Grifstar,
That was Flat tappet cam 660 lift cant remember all the specs of the cam 12 to 1 compression flat top motor. Motor ran 9.20 at 145MPH+ in my 10.5 2850# mustang spinning 10-20' out from hit.
1 - 7 of 7 Posts
