bbf powerglide SOLD<<<<<<<<
i have a powerglide with about 15-300 ft passes on it it is set up with a jw bell for the 429 460 bbf motors , deep aluminum pan best of everything inside , pro tree valve body with pro tree brake,9 drum pack , all roller bearings , a vasco 195 racing planitary , harden in put shafts turb spline , R servo ,tci sheild , aluminum rear roller bearing support , 2 coan race converters 4800 and a 5400 stall both with anti ballon plates , trans was set up for a bbf 606 inch motor , ,,,,,,$ 2500.00 or 1700.00 without converters 1500.00 without bell and convertersemail [email protected] 517/285/4751 thanks for looking Phil, trans located in fowlerville michigan i can help with delivery or meet you I ALSO WILL TAKE A PARTIAL TRADE ON THIS let me know what you have im looking for a dana 60 king pin front axle ford , heads , intakes, or ? any bbf stuff
Discussion Starter #2
will sell without converters for 1700.00 and 1500.00 without bell housing and converter(s)
Is it a stock case?
SOLD!!!!! :D Thanks Phil :)
