1 - 13 of 13 Posts
FOR SALE
Im moving onto a new turbo small block project guys so all my BBF parts need new homes.
I have:
New Eliminator Premier block. Its as delivered from Eliminator $2850
TFS A460 heads. 87cc Complete w. 2.35/1.88 stainless valves, nextec springs, mild porting $2650
Forged 557 Rotating assembly. 4.5 Scat 4340 crank (std/std),
Eagle 6.8 H Beam rods w. ARP 200 bolts. JE flattop 4.44 pistons w. tool steel pins. $1800 SOLD
Balanced, never hurt.
Danny Bee billet belt drive assembly w.
stainless timing pointer from KFR great shape. $850
TFS Tall single carb intake for A460 heads. Powder coated w. black wrinkle finish.
mild porting. -10an bung welded in the rear floor for vacuum pump. $450
Peterson Wetvac external oil pump w. pulley (has oil/vacuum pump in one unit) $850
Moroso flat bottom kicked out chassis car oil pan. Internal oil pump pickup tube, $300
(was converted to external pump)
Meziere bbf electric water pump (black) w. outlet fitting $225
Induction Solutions Saturday night special nitrous plate (100-300 jetting) $400
(w everything but a bottle)
Black TFS 1.73 roller rockers $225
(have a few spare blue motorsport rockers ill include too)
Nextec take off springs New unused
1.640" O.D. dual spring with damper 250 lbs. @ 2.000" installed height $215
800 lbs. @ 1.150" open 600 lbs. per inch rate .850" maximum lift
Crower unduramax bushed solid roller lifters .874 $850
CSR aluminum 164tooth flexplate w, current sfi cert. Has removable bolt on $210
ring gear.
Ford Mini Starter (from NAPA) $80
Jomar 1" powercone tapered carb spacer fits 1150 holley 4500 $60
Magnafuel Quickstar 300 fuel pump w. built in filter. -10an fittings $350
Magnafuel 4port fuel pressure regulator w. guage, fittings $150 SOLD
and billet carb mounting bracket
Reid racing ultra glide bell housing for BBF (current cert) $275
Custom Ground solid Roller cam from Chris Straub 280ish duration @.050 $325
.780ish lift (pm for full specs)
Keith fulp racing mild steel midplate $60
Aluminum danny bee front motor plate from keith fulp racing $100
Dana 60 rear 4.10 gear set (used 2 seasons) great shape $100
BBf tall smooth top valve covers. black wrinkle powder coat finish,
Billet alum oring fill cap welded in $150
MSD 6AL2 ignition box (built in rev limiter and twostep) $150
MSD adj single stage timing retard w. adj start retard. $85 SOLD
MSD 8580 distributor new cap and rotor, bronze gear(may need replaced) $165 SOLD
All these parts (except the block) were used for a few seasons on my pump gas 557.
Never hurt or abused. Prices are plus shipping from 83644.
1 - 13 of 13 Posts
