1 - 20 of 29 Posts
Banned
BBF 557 SALE...........
CAME ACROSS ANOTHER SETUP SO IM SELLING THIS ONE..
Engine: 460 t0 557 BBF
1971 CJ DOVE-A block bored .080 to 4.440". Honed for moly rings. It’s been parallel decked and cut for O-rings. O-rings have been installed. Main saddle has been honed true to cylinder bores. Lowest point on any non thrust flange is .178" before the bore job which leaves .138". 4-bolt mains, new ARP studs included for the heads and mains. Half fill of blocrete. Good to 1500 hp. $2000.00 in machine work alone.
BLOCK 1500.00 O.B.O
Trick Flow A460 heads TFS-5450T801 (new in box) 2300.00
Trick Flow rocker stud girdle TFS-54400700 (new in box) 220.00
Trick Flow roller rocker arms TFS-53400621 (new in box) 220.00
Trick Flow tunnel ram top gasket (extra) (new in box) INCLUDED IN TUNNEL RAM
Trick Flow black valve covers TFS-53411802 (new in box) 110.00
Trick Flow A460 tunnel ram TFS-54494000 (new in box) 600.00 COMES WITH TOP COVER AND GASKETS
Trick Flow A460 tunnel ram top cover TFS-58594140 (new in box) INCLUDED IN TUNNEL RAM
Isky Red-Zone roller lifters ISK-3172RH (new in box) 675.00
Holley 4500 dominator carburetors (1) HLY-0-9375-1 650.00
(new in box) sold other
Summit timing chain cover SES-5-80-04-201 (new in box) 75.00
ARP stainless 12-point intake bolt kit ARP-455-2101 (new in box) 40.00
ARP cam bolt ARP-255-1001 (new in box)
Milodon gear drive assembly MIL-14600 (new in box) 250.00
Custom forged JE pistons approx 14:4.1 (new in box) 1200.00 NEW -----
Scat forged h-beam rods 2-454-6800-2200A (new in box)--------------- PISTON, RINGS, RODS, CRANK 2300.00
Scat forged crank 4-460-4500-6700-2200 (new in box)------------------
Perfect circle rings 315-0057005(new in box)----------------------------
Pioneer harmonic balancer 872036 (new in box) 170.00
JW flex plate for powerglide JW N93001 (new in box) 150.00
JW Trans Crank Sleeve 80002-1( new in box ) 20.00
Balanced rotating assembly
Custom comp cam by Lem Evans 34-009-9 (new in box) 300.00
Motofeet engine stand
Skinny Kid Race Cars BBF mid plate for offset crank (new in box) -------------------------
Skinny Kid Race Cars BBF front plate for stock cover and offset crank (new in box----------- PLATES TOGHETHER 220.00
KEEPING PISTONS,RINGS, CRANK AND RODS TOGETHER.
Auction Block Rules
1) You MUST state your price in the ad
2) You MUST state your location
3) No links to Ebay ads. If you want to sell it to forum members, list it here.
1 - 20 of 29 Posts
