1 - 12 of 12 Posts
76 Tbird Block, Fully machined
Eagle 521 stroker kit, cast crank, Hbeam rods, Forged Mahle Flat tops, ARP main studs
Lunati Voodoo HFT camp, 241/249, .581 & .6 lift
Edelbrock 95cc heads with ARP head studs
trickflow 3/8" moly pushrods
SRP billet 1.73 Roller rockers
Jomar stud girdles
Edelbrock torquer II intake
Moroso Fabbricated Valve covers
Innovators West Balancer
FRPP rear sump fox body oil pan, melling HV pump
SFI flextplate
All hardware is ARP stainless
Billet specialties spark plug wire looms with summit low ohm 8.8 custom spark plug wires and NGK plugs
accessories
Flowkooler HV water pump
CVX racing billet accessory bracets and Billet pullies
Ford 3G 130amp 1 wire alternator
New sagnaw power steering pump
Aluminum spun drop base circle track air cleaner wrapped in carbon fiber vinyl and 14"x4" K&N air filter
Located in northern NJ, 07052. Can put this in the back of my pickup and deliver if its not too far away. Shipping on buyers expense. Asking $5500 for whats above, easily 15k in this motor. Open to reasonable offers but nothing below 5K.
I can include a billet 1000cfm prosystems carb with feed line kit -8an and lots of goodies including holley jet kit, power valves, new gaskets and stuff for a total of $6000. Carb and goodies $900 picked up, $950 shipped
Alt removed to pull the engine but comes with purchase.
Discussion Starter #2
Forgot to add but motor purchase comes with fabbed aluminum HOWE 31x19 radiator, dual 1" cores, ford inlet upper pass side and lower driver side. Included is a dual electric OEM GM dual 13" cooling fan with integrated shroud. They pull some serious air!
has the engine ran? if so for how long/miles? what is the CR?
Yup, has about 500 street miles, city and highway going to track 1 time and lots of car shows. Has 3 runs down the track with a best of 12.1 at 115mph but I wasn't pushing past 4500 Rpms as the motor was rather fresh and it wasn't for WOT tuning, new prosystems carb so was tuning low/mid throttle and transitions etc. Besides the actual miles it has lots of idle time etc.
Compression is 10.8:1 static and like 8.875 I think dynamic without the sheet in front of me. Aluminum heads allow 91-93 pump gas all day and that's what it was run with.
Huge Price DROP! Dropping price of motor to $4500 and will deliver if a reasonable distance to meet up or something. I won't be able to move this after the next week or two as my first kid will be coming around that time. I have to get this out hence the huge price drop.
Interested in selling the top end?
D
Update, local guy put a deposit down on the motor so sale is pending. Will know more in a few months and will update the thread. He's only taking the motor and carb so I have to get rid of everything else.
For sale
1.) rad and cooling fan combo
2.) barely used procomp mechanical high flow water pump (edelbrock copy) with backing plate ,
3.) new OEM waterpump sealed with POR15 and painted in high temp aluminum silver
4.) BBF to GM trans adapter entire kit including SFI dual pattern flex plate
5.) used OEM timing cover, blind bolt boss broke off inside as a small chip but ran it with no leaks
Wish i would of seen this in time.. i would of found a way to ship it ...Let me know if it falls out!
1 - 12 of 12 Posts
