1 - 19 of 19 Posts
Okay Guys,
Many of you remember the Donald Bowles / Jack Roush operation that was at the BB Ford Bash. According to our Mr. Mayfield the Roush/Bowles group rented the track yesterday and were there testing. Jack himself, along with his daughter and son-in-law, Donald Sr, Donnie Jr and the main guy from the E-85 fuel deal. They had all 5 Mustangs along with all the cars that we saw there last year, including the old Falcon with the FE engine.
Later,
Do we know anything yet about the experimental engine?
Is Ford going to replace their 385 series crate engines with this new engine?
I talked to a good friend of mine in the Ford Performance tech group yesterday and he told me that they're not replacing the 385 series engine itsself, but more to the extent of replacing the 514 crate engine.
He stated they are working on "possibly" a bigger crate engine that will still be based on a newly designed version of the current A-460 block, but that it will still be a 460 "based" block design...
He also said that whatever Donald Bowles & Jack Roush are working on/developing, that Ford is is not directly involved.... "as far as he knows"
Doug... 8)
Lem Evans said:
Yes...a bigger 385 crate engine is MUCH talked about .
OOH LEM, DO TELL!!!!!!!!!!!!!!!!!!!
You know you know so go ahead and spill the beans....
Anybody know how the Bowles E85 Hurricane motored car did in testing????
I do not know what the C.I.D will be or if they will do it...just that it has been discussed....Chevy having a bigger crate engine has a lot to do with it , IMO .
I don't know if this is the kind of info you guys were asking about but here's what I know about the new Roush 588 engine. A guy (Dave) from Canada had one in his Starsky and Hutch torino, met him during Hot Rod Drag Week. this is info he posted on the torino forum. Impressive if you ask me, considering he drove it over 1000 miles and made passes in the 12's if memory serves. If there's something bigger and better let me know.
My serial number is 588 002
Displacement: 588 cu. in.
2 year warranty
Advertised: Horsepower 630 hp, Torque 690 ft-lbs.
Block: Ford Racing A-460
Crankshaft Type: Nodular Iron (Externally Balanced)
Bore and Stroke 4.560 x 4.500"
Connecting Rod Type: Forged 4340 Steel "H-beam"
Compression Ratio: 10.25 : 1
Pistons: Forged
Timing Chain: Double Roller
Camshaft Info: Roush Proprietary
Lifter Type: Hydraulic Roller
Cylinder Heads: Aluminum
Intake Runner Volume: 290 cc Super Cobra Jet
Combustion Chamber Volume: 61 cc
Valve Sizes: 2.200" Intake 1.760" Exhaust
Rocker Arm Ratio: 1.7:1
Spark Plugs: Autolite 3923 (or comparable)
Intake Manifold: Single Plane
Fuel System: Holley HP 1000 CFM Carburetor w/ mechanical secondaries
Fuel Requirements: Premium Unleaded (minimum)
Max. Recommended RPM: 6,500
Firing Order: 1-5-4-2-6-3-7-8
Timing: 31 to 34 degress @ 4,000 rpm (not to exceed 35)
Oil Pump: High Output - Adjustable
Oil Pan: Dual Sump (FOX Mustang)/Other Configurations Available
Oil Filter: Motorcraft FL1-HP (or comparable)
Oil Weight: 10w30
Flywheel: Steel, 157 tooth (Aluminum Available) Externally Balanced
Starter: Ford Motorsports Super High Torque (1.6kw) (or equivalent)
RPM HP Torque
3000 378.9 663.3
3100 393.7 667.0
3200 407.7 669.1
3300 421.2 670.4
3400 435.1 672.2
3500 449.4 674.5
3600 462.6 674.9
3700 476.3 676.1
3800 491.8 679.7
3900 506.9 682.7
4000 521.0 684.1
4100 535.6 686.2
4200 549.2 686.8
4300 562.7 687.3
4400 574.9 686.3
4500 585.4 683.2
4600 594.2 678.5
4700 601.0 671.6
4800 607.5 664.8
4900 613.5 657.6
5000 619.9 651.2
5100 624.8 643.4
5200 627.2 633.5
5300 629.2 623.5
5400 629.8 612.6
5500 629.5 601.2
5600 628.2 589.2
5700 625.4 576.2
5800 620.3 561.7
5900 610.6 543.6
6000 601.0 526.1
Did anyone look at the engine in the yellow car? It is a modular engine but is a lot longer than the 5.4 or 4.6. We talked to Don Bowles about it and he said he couldn't say much about it but it was an experimental engine from Ford. It must be pretty stout to run 9.00 in a car as heavy as that.
Discussion Starter #14
Phantasea466 said:
I didn't get ca chance to look at many cars, wish I had but time seems to fly by....... We did talk to the guy in the white car while in the tech line.
"The guy" in the white car is Mr. Donnie Bowles to you, Twinkle Toes :!: He's very nice and cordial. Speaking of the white R&D car, did you notice the big B.F Evans Raceparts decals on the quarter panels?
Also, I'd like to know why you didn't join those of us who were sipping a little moonshine in the parking lot of Rafferty's after dinner late Saturday night? Was it because your wife was with you :?: :lol: :twisted:
He, heh, he,
Uncle Charlie,
We (Chuck and I) did notice the BF Evans decals on the quarter panels. We were telling Donnie that we were at the BBF Bash. Where's my BF Evans Race Parts decals :?: 8)
Donnie was showing us how the body is offset to put more bite into the right rear tire because they can't do much adjusments on the factory 3 link. I agree, Donnie is very nice and easy to talk to.
Moonshine :?: That was Moonshine? I thought that was kool aid :p
I looked at the engine in the yellow car. I had to look at it twice because I thought it looked like a V-10....nope, only 4 tubes per side.
I talked to the guy at the Ford trailer about what was going on with the BBF crate motors. Also asked him about if they were going to go any bigger than 514 since Chevy has the 572 and such. He said the main reason why they took off the BBF motors were because they had ran out of the blocks they were casting for the motor and that as soon as they were going to order more they closed the doors to the facility that makes the castings. He said at this time they were moving the casting to a different place and were going to cast the newer motors based on a A460 block. He said at this time he had heard of no plans to go to any bigger motors and that until late next year you would only be able to buy a 460 not even the 514. Not sure if he knows what he is talking about but he did say any other BBF motors that Ford might come out with would be no sooner than the end of 2008.
later,
Doug Benton
I think I have fiqured out what that new engine is!
The new technology, named TwinForce™, will appear on future Lincoln and Ford vehicles.
TwinForce uses direct injection technology and turbocharging. These technologies are common in diesel engines, but have only recently been combined for use in gasoline engines.
“Everything we do is driven by our customers,” said Derrick Kuzak, group vice president, Global Product Development. “Our TwinForce engine technology is a key element of how we’re going after fuel economy gains without asking anyone to give up performance.”
TwinForce’s direct-injection fuel system is different than conventional port fuel-injected gasoline engines. Instead of squirting gasoline into the engine cylinder head, it directly injects gasoline into the engine’s cylinders at high pressures.
1 - 19 of 19 Posts
