1 - 11 of 11 Posts
BBF 555ci [/b]
- IDT Premier block
-Bryant light weight billet crank
-GRP 2000 pro series aluminum rods
-King main and rod bearings
-Ross digitize pistons and CNC domes
-Moroso custom aluminum oil pan
-Trickflow A-460 heads with custom titanium valves,alloy seats,psi valve springs,mainly titanium retainers,hardened locks
-Trickflow A-460 4500 intake
- Jesel custom rocker arms
- Jesel front drive kit with distributer
- roller cam bearings
- Comp cams custom grind solid roller cam-shaft
- Isky BBF .904 roller lifters
- Total seal custom piston rings
- BHJ lifter bore bushing's
- ATI balancer
- Danny bee thrust plate with double torrington bearing's
- Mainly 7/16 push rods
- 4 stage moroso dry sump system
- Moroso dry sump tank
- Moroso 4 vane vacume pump
- Meziere BBF water pump
- MSD flying magnet crank trigger
- BES sheet metal valve covers
- Dale cubic CFM 4500 carb with cnc spacer
This brand new setup only has 35 passes and just won the canadian nationals runs consistantly 8.20's has been 8.22 @169.87 mph has been 174.66 mph on a 29.5 tire @3270 pounds.
also will sell converter with motor
-8'' Neil chance all aluminum billet converter bolt together with 3 billet stators.
serious inquires only email me at [email protected]
price and local is the rules here . rules posted above . New rule no price its free , forget about the local , just PM your address and I'll be by to pick it up . lol .
rules
And I see that it still the same here as the other site! I wish evryone was as perfect as most that do the correcting! Let the moderators do it?
Dan
Also do you have a dyno sheet? I didn't know that those heads would flow enough to run that fast for the wt. on just motor and one carb
BBF 555ci [/b]
- IDT Premier block
- ATI balancer
The motor just sold owner has dyno sheets, and if you want further specs on the engine and how it made that much power you can call tony bischoff at BES racing engines.
that was quick . care to say what your next build will be
Everything that seems to leave Bichoff's shop turns out good and he will do custom work, to make it work if necessary. I think heard truck pullers deal with him alot and people that money is know issue.
1 - 11 of 11 Posts
