I currently have A 557 w/P51 heads & solid roller cam 14-1 compression SV1 carb wondering best intake for sand drags. Thanks
did you dyno it as it is? what rpm band does it run? heavy car/truck?
converter stall?
No we didn't dyno it. truck weighs about 2800# Running around 7000 rpm. cam has lift .787 intake .780 ex dur 276 in 290 ex @ .050 111 centerline 4600 stall converter powerglige w/trans brake. currently running victor that has been ported to match heads
need to change the cam and port the intake,and the heads if they havent been already
nothing wrong with that intake,unless you can run a tunnel ram
