1 - 20 of 30 Posts
Thinking about selling off the Ranchero and another vehicle and replacing both with one 385 series powered 4x4. At the moment the Ranchero hauls parts, and the 4x4 hauls the canoe and takes my wife and I into remote parts of our region.
The obvious choice is a 70-something F-150 or F-250, but those are really just too big for the trails in my part of the world.
Thinking about a Ranger with a 460 conversion. Maybe with a 370 industrial block and a 2bbl intake. My main concern is trans/T-case/axles. Are we talking full custom fab here, or does somebody make a 4x4 conversion kit?
Is there some other 4x4 chassis I haven't considered?
Why even do a big block if you're gonna use a 370 with 2bbl intake? How 'bout a 351W instead? Smaller, lighter, make as much power. Stick one of those in an '85 or newer Ranger or BroncoII. The axles MIGHT hold up to it. I'd use an AOD trans with whatever matching T-case comes on it for the swap.
Holly crap, you need a D-9 with that terrain. :shock:
I like the idea of an early Bronco, 66-77, but it would be a ton of work to make a 460 fit. I put a 351C in my 72, and any more would have required serious firewall and floor surgery. The frames are stout enough, but of a tube design and too narrow for the stock 351 manifolds to clear, and even with full sized F150 axles the off the shelf fenderwell headers were too wide due to the engine sitting much lower than intended for a F150.
Why not use a ScoutII? You are familiar with them, the 460 would be similar in size and weight as a 345. It would need a 9"/Dana 60 as the rear Dana 44 wouldn't be happy long. Get an older one with a Dana 30 out front and a Ford high pinion Dana 44 could be swapped to the front to get the driveline on the right side and disc brakes. If you really wanted to do some changes, swap in the Ford radius arm and coil spring setup in the front from a donor early bronco with a D44, but it is a low pinion deal. That 2 bbl manifold would come in handy if you wanted to use projection or something similar... or you could always ship it to me and I would put it to good use :D
Tom
I would try to find a 1972 International Scout...Find one that the whole top comes off....if the view out my back door looked anything like the pictures above....I would have a 521 in a dune buggy going right up the side of those hills....
Ummmm, because I'm a BBF guy? I've been building them since I was 14 years old, and it's all I build for other people now. Call it an obsession. Why a 370? It's got a 7.5:1 compression 345 2bbl now and it has all the power I need, plus it gets 18-20 mpg cruising the blacktop in the mountains.
ProStudebaker said:
how about an old style bronco not the big body but the little version . with a 460 of coarse brad
Not enough cargo room. I've half considered chopping one up and extending the wheelbase to add a real bed, but I just don't have the time. Not to mention, those little Broncos are bringing big $$$ these days.
Well, it is a 78 Scout II, and the top does come off every spring, then it goes back on every fall. Part of the reason I like it......
460 into the Scout would require a driver side drop as far as I know (new trans, T-case, axles, etc.). A guy here in town did one. Ended up with a Scout body sitting on an F-250. Too wide, and too much work.
I really like the Scout. My problem is that it's not a Ford. It does use an FL-1A oil filter though!
I'd be willing to do an engine/trans/case swap, but I don't want to get into new axles and suspension.
Hmmm, this thing has a 727 trans. Could I just get an adapter plate? I'd hate to lose the Tera-Low20 case I just built.
Carl, finding an early bronco chassis or parts is fairly easy, and relatively cheap since so many of them are going to full width axles and Dana 60s. The 9" is about 1/2" wider, and the Dana 44 is within 1". The radius arm c-brackets can be cut off easily with cut-off wheels... I have done a few. On the rear, its nothing to move spring perches. If that is not an option for some reason besides budget... there is the Atlas transfer case which I believe can be clocked to to other side of a Ford trans.
I bet you could find a local axle builder that would be willing to cut down a full sized Dana 44 from an F150 to the dimensions of the Scout II housing so you could use the IH internal parts swapped side to side. This is usually done by cutting/removing the knuckles and cutting tubes to length, and replacing the knuckles at the same angle relative to the original angle. The problem with using the IH housing is that the spring mounts are made into the housing, as the fords are not. That is one of the reasons I mentioned using the Ford (early bronco) front suspension with the coil springs and radius arms.
Tom
The IH 727 case uses a different bellhousing pattern than a Chrysler case. The internals can be swapped to a Chrysler 727 case, and then an adapter could most likely be had to mate the BBF to a Chrysler 727.
I happen to have the 727 from my old 74 Scout II that had a 258 straight six. Would that work with an adapter plate? Has the IH/Texas D20 flange on the back. :D
Only put 300 miles on the engine and trans after rebuilding them before I wrecked the damn thing. Saved the trans, sold the engine (4.0L head swap), sold the axles, etc. and then sold the body/frame to guy that wanted the title and vin plate.
That, I do not know. I have not messed with any of the 258 IH stuff... my IH friends only have 304-392. Zephyrbob might know?
Tom
Why not run a 78/79 full size Bronco? They take a 460 real easy. Can go anywhere that a scout can go.
The 78/79 Broncos are a good 5"+ wider... which makes for some interesting trail riding when you are looking on the down side of a mountain like Carl listed above. I agree, they would be a whole lot easier to make the 460 swap.
Tom
I built my 4X4 using a 1967 Scout I installed Dana 44's from a Scout 11 I narrowed the rear 7" and the front 5" I did them myself & Moser did the respline for me on the axles. I used a ZF 5 speed and went with a left drop. I now will recut the front and use a Ford 44 for the left drop change over. I built a very low RPM high Torque 460 using F3 fuelie heads. I have big tires all inside the body lines. This rig will drive all day long with 3:54 gears and the big overdrive = very good MPG. I can go places a late Bronco never dreamed of. Best of all I did it on a very tight budget. Paul Kane has seen and drove it so it's now it's a historical artifact.
Van
Discussion Starter #16
All that fab work takes big chunks of time. Think I'll have to look into an adapter for the 6cyl 727.
The rest of the combo works really well. It's got Dana 44's front and rear with a reverse shackle front end and 3" lift springs all around on 265/75/16's (32x10.50). The axles have 3:07 gears, but the Tera-Low kit in the t-case makes low range the same as having 4:88 gears with a stock Dana20 case. Basically an underdrive instead of an overdrive.
Hey Carl, I have lots of pictures of this build and I'll throw a few up here. Also, I should probably start an entirely different thread about SHOEHORNING a 460 into a 1968 Scout. There is plenty of room sideways (fenderwell-to-fenderwell) as Vandy notes, but Van is also very, very, VERY humble and unassuming when it comes to his fabrication skills and craftsmanship....and so what he does not realize he needs to tell everyone here is that he completely reconstructed the firewall to accomodate the engine, trans tunnel mods and fabrication for mounting all the shifters, re-hanging the gas, brake and clutch pedals to the left because of the widened tunnel/firewall mods, etc. (Just look at what he posted above for the axles alone, for example.) The welding, sheetmetal work, engine build, compartment fitment and re-configuring, raw materials fabrication, paint and body, etc is all second nature to him. This is why I took picures...because I was so amazed at the lengths Vandy went to in order to make it all work. To him it's nothing.....body, paint, welding, sheetmatal fab, cutting, grinding, the list never ends--he does it all himself. But for most it's a long painstaking project, not just a few weekends here and there. I swear I could wake that guy up at 3 a.m. from a dead sleep and throw him in front of a throttle blipping nitro motor and with one wiff of the exhaust he would say, "drop your injector size by one step, go from 65% nitro to 70%, and take 2 degrees out of the timing, then she'll run." His Scout is awesome but it is not a walk in the park for most to do what he did. :shock:
Damn you, Van! Is that rear-engine rail chassis still sitting idle on the jig? Get back to work!
Paul
like others have said, a 66-77 bronco would be PERFECT for your situation, I just finished my 73 with a clevor in it and it works great anywhere and its nice and small for the mountains, and you got to love the SHORTWHELLBASE of those little things, throw some 35's on it and your good to go :D
460 In 1968 Scout
Note sheetmetal fabrication for clearance of transfer case (beneath seat mounting/lower right corner of photo) as well as transfer case stick fab work. ZF-5 speed is long in this little truck:
Below: Firewall widening to accomodate engine & the fabrication of 4WD selector stick box:
Coming into shape nicely:
Just needs prep & paint:
Engine fitment: note recessed area in firewall, late model fusebox & wiring, Poly-Vee accessory belt drive system, etc:
Addition of power steering proved to be tight but doable with futher mods (offsetting):
Passenger side:
The engine sits very well between the frame rails and the 460 fuelie headers look like they were made for the Scout. Overall it's a very clean and organized install; I still think it's a big project for most people...Van makes it look easy.
Paul
1 - 20 of 30 Posts
