1 - 12 of 12 Posts
My uncle is building a 454 and he got a cam that supposed an "Angle" , is there a brand like this cause i never heard such thing?. Anyway, he likes to know the specs for this cam, supossed to be a solid. The only numbers and letters t+hat are in the cam are this ones:
ANGLE NF73-85 112 F
I know it is chebby question but i d like to help my uncle.
Thanks guys.
Homer
Discussion Starter #2
Ok i found it. It is an "Engle" cam. Now i just need to know the valve lash adjustment.
Specs are:
valve lift .580, .620
adv dur: 306, 318
dur at .050 : 267, 274
lobe center: 108
Anyone?
Iron heads, will it matter if he is using or not roller rockers for the adjustment?
Well, that is a good start. That is the bad side of buying used cams withouth cam cards. Thank you guys very much.
HOmer
Well, it is all said. 8)
Thanks again boys.
Homer
Discussion Starter #12
:D :D :D :D :D
You helped me anyway, appreciate it. Alcohol cams uh, man i think that gasoline was made for the cars and alcohol to knock down th human strokers, i am at least a 557!!
Just kidding man :D !
Thanks again, you guys are great.
Homer
1 - 12 of 12 Posts
