I love this car and dont have to get rid of it. I am wanting a change.. Im kinda wanting a turbo car. Will trade for Lightning.. Or another race car...
ALL lights work Can be drivin on the street!
466 With only around 15 passes on it
Dome speed pro pistons
Stock crank
H beam rods
All balanced
King bearings
Procomp aluminum heads ported with good ferrea valves
Dubble springs ETC ETC
Comp cam 34-343-4
Dommy gas 1050 carb
BIG ceramic coated long tube headers with bullit mufflers
CSR water pump
Big aluminum Radeator
Duel electric fans
MSD 7AL ignition box
Dynamic C4 with JW bell
C6 upgraded front section
4500 stall
Trans brake
10 point cage
8.8 rear with spool and moser axels
ETC ETC.
Double cross bar plate kit on it. with a VERY save tune 65n 53f car goes 9.40s at 142 so far. Still tuning the nitrous and susp.
Susp.
QA1 Adj. coil overs all the way around
Anti roll
Subframe connectors
Aftermarket rear control arms
Mini tubbed
drag lites wit 15x10 rear and 15x3.5 in the front
29.5/10.5 stiff side wall slicks
SHOW ME WHAT YOU GOT... Not sure about letting it go so make the offers good. Might trade for an unfinished car if its a good enough deal.
Stock crank
H beam rods
All balanced
King bearings
Comp cam 34-343-4
Dommy gas 1050 carb
CSR water pump
Duel electric fans
4500 stall
Trans brake
10 point cage
ETC ETC.
Susp.
Anti roll
Subframe connectors
Mini tubbed
