I've changed directions and going with a small block so I've got a stroker kit for sale that was to be used for another engine. It's a 4.300 Scat Cast Crankshaft 3.000 Mains and 2.200 Rods, back from the machine shop 0 balanced with Mallory and turned .010-.010 checked for straightness. Also a set of Eagle 6.800 rod also checked and refurbished (needed very little) and a set of Wiseco Pistons, CJ Heads 4.390 Bore, 1.352 comp. Ht. w/pins 14-1 comp w/76CC volume.
The history is I broke a rod bolt took out 2 rods and pistions. The crankshaft had some slight nicks that were taken out by turning .010 and the main were turned as well just for GP. The pistons are coated on the skirts, all are good except one which should be replaced if I was to run them (but that's your call). I have the spec sheet that was sent to Wiseco and the cost was $88.21 each.
I'll sell this complete set-up for $900.00. If you want it separated then $350.00 for the crankshaft, $350.00 for the rods and $350.00 for the Pistons. Plus shipping.
Any questions, please give a call as my cell is always on. Gordy 269-217-8570.
update
The Rods and Crankshaft have been sold. The pistons are the only thing left. If you're interested shoot me a message/offer. Thanks to all that responded and 460Ford.com!
Gordy.
