1 - 3 of 3 Posts
cam was in tony akins motor. I sold the motor and guy bought smaller cam and using c6
jw wheel $100
cam $150
Serial # F 6823-05 Spec Card# 08474505
Part # 34-000-9 CAMSHAFT, FF FORD 429-460 ROLLER
Core C34-9E CAMSHAFT BLANK, FF 429-460 STEEL-BIG BRG
Grind # FF 1718R /1209R SR115.0
DURATION @ .050 INTAKE 285 ROCKER ARM RATIO
VALVE ADJ INTAKE .022 DURATION @ .050 EXHAUST 308 INTAKE 1.70
VALVE ADJ EXHAUST .022 LOBE LIFT INTAKE .4710 EXHAUST 1.70
VALVE LIFT INTAKE .800 LOBE LIFT EXHAUST .4610
VALVE LIFT EXHAUST .783 LOBE SEPARATION 115.0
DURATION .020 INTAKE C/L 115.0
TAPPET LIFT INTAKE 318 CAM ADVANCE 0
TAPPET LIFT EXHAUST 348 HYDRAULIC
VALVE TIMING .050 OVERHEAD CAM N
VALVE OPEN INTAKE 27 JOURNAL DIAMETER STD 2.224
VALVE OPEN EXHAUST 89 RECOMMENDED VALVE SPRINGS
VALVE CLOSED INTAKE 77 DEPARTMENT P
VALVE CLOSED EXHAUST 39 SPC INSTR FOR CUSTOMER
RUSTANG CAMSHAFT
1 - 3 of 3 Posts
