1 - 20 of 26 Posts
Has anyone had experience with both shops? At first I was 100% set on Bigs, but I have since read about Prosystems and question whether Bigs is a top shop now? Looking for dual double pumpers for a tunnel ram 521.
Any help is appreciated.
Jeff
Prosystem all the way- you'll be as happy as a pig in S**T......lol:D Patrick is the man for the job!!!
I have a 1050 & a 1150 that have been touched by Patrick at Pro Systems & they were near perfect (jetting) out of the box !!!
ProSystems!!!
ProSystems.. Patrick nailed mine.. I also have a 521 that i just fired up and it was right on the money.. Great to deal with also, answers all your questions fast... You won't be dissapointed!!
I've used both Bigs and ProSystems, Jesse is a nice guy and the carb worked pretty good. I had some issues with surging and plug fouling and Jesse took it back and made it much better. I had it for a few years and then I replaced it with the new SV-1 carb from Patrick @ Pro Systems and it's been excellent so far.
just got our sv 1 running had some problems got a hold of patrick at 4 pm on a saturday and he walked us through what to do the best he could over the phone cant get much better service then that
Same as 3DMUDRACING, great service. Prosystems are great to work with even after hrs
and weekends. Had Patrick build single dom that I supplied, and later purchased 2 doms
from him later for t/r set up and both worked great out of the box.
pro-systems,patrick is the go to man on carbs,put my 1200 dominator on the didnt have to turn a screw,only changed the jet because we went to q-16 vp gas!! look forward to working with him in the future.
pro systems
Another for ProSystems I've got 2 carbs of them a 750 for a 347w and a 950 for a street/strip 460 and found them to be great to deal with,
I'm in Australia, and the quality is fantastic...
I've used pro-systems as well as a couple of friends of mine. No adjustments other than turning the idle screw. Spot on, out of the box!
Had good and bad luck in the past with Pro systems
1 spot on...;)... 2 needed some tuning....:rolleyes:.... 1 WASN'T drilled (metering block)....:mad:
I now go with AED
ProSystems. Service at it's finest.:)
never tried any other shops but Pro Systems did my 1000cfm 4150 series for my 514 could not be happier ... 1/4 turn on the idle stop screw and it runs like a timex watch ....
Pro Systems for me next time again
1 - 20 of 26 Posts
